What trolley jack does everyone use?
iimushroomzii
Toilet roll king
  Transit Connect.
Thread revival, after recommending the SGS that I have...
It stopped lifting the car the day before I went to the ring, not ideal. Had 2 years use out of it, but it has lived outside to be fair.
Looking to replace it but want something that can reach to the subframe as the sills on my 182 aren't the best.
Have you tried bleeding the air out of it?
JamesBryan
Yeah.... leaving it outside probably isn't the best haha.
To bleed them, there's usually a bung in the piston/cylinder. Remove that and turn the handle as you would if you were lowering the jack and give the handle a few pumps.
  172
The bleed them, there's usually a bung in the piston/cylinder. Remove that and turn the handle as you would if you were lowering the jack and give the handle a few pumps.
To be fair it lives outside but in it's plastic case thing. I'll give that a go before I chuck it out then
imprezaworks
  Mk5 Golf GTI :)
Yeah mine lived outside naked, pretty sure that's why it broke lol.
If I was to get another. I'd get a better one and not leave it outside :)
Louis
I Park Like a C**t
My sgs one has been perfect. Reaches the subframe easily too but my cars not lowered.
Only thing I don't like is its not always smooth to get it to come down, but I can live with that.
Danith
  MX5 ND2/220 Trophy
SGS engineering low entry with the carry case - bloody heavy so case is needed!
dann2707
I wish I didn't buy my sgs jack. It's cheap and pretty gash. Doesn't hit the subframe and doesn't hold the car very well.. The Jack drops a lot over a short period of time. Next purchase will be a proper one.
For the price it isn't too bad I guess.
JamesBryan
Get the 3 ton sgs jack. You'll never need another one again. It's f**king heavy mind, but it's solid.
Had mine for years now.
Gus
  182Turbo,DCi90
I have the "low entry 2 tonne SGS" too. Not very impressed with it though as it wont get under the 182 or the 200 without driving the car onto some small ramps.
Mine also doesnt hold its position once jacked up and the car sinks slowly. For the price though its pretty good.
Looking in to replacing it with a decent one though.
Sunglasses_Ron
ClioSport Admin
This massive bulky s**t thing which barely fits under my car.
I've got that f**king thing.
I took a wheel of the give it a good clean the other day and the jack started to drop. Luckily my neighbour was outside and was able to pump the jack while I put the wheel back on.
My cousin has a tyre shop and swears by the Costco jacks. That's my next purchase.
MRBILLYUK
  FF Jeden Osiem Dwa
It might just need bleeding and topping up with oil . It's only about a fiver for 500ml of hydraulic jack oil .
