Low boost conversion
  Clio cup/Transporter
Hi all i currently have a Clio 172 cup and im thinking of a Low boost turbo conversion.
The car is currently on 110k miles and im wordering if the engine would cope with the extra performance. I dont want to blow the engine up.
Its it worth it or not??
  182 Turbo
Do a compression test, make sure the cambelts done and if its a healthy motor thats had a good life, why not.
cjgower
Depends really. Is the car mechanically sound right now? providing it's got good service history the engine will likely be sound. It's everything around it you have to worry about. Clutch, engine mounts, gearbox, driveshafts etc are all things that will be under more strain.
I went for low boost at about 103k and the car is now on almost 113k. It will be two years in December and it's still going well!
During that time i've had to have a Helix Clutch fitted as the standard one started to slip other than that it's been spot on.
  Clio 182
Speak to engine dynamics. Andy over there will be able to advise you on this hes been doing them for 13 years!
  172 Turbo
I wouldn't bother.
£3200 low boosts your car.
Or you can buy a boosted car with a similar spec for £3000-3500, sell your car and you'd get much better spec for £5000-5500.
Boost should be the last tick on the spec sheet, after suspension, brakes and diff imo
  Clio 182
  Clio 182
I wouldn't bother.
Or you could fit it yourself [emoji6]
  Clio 182
Whilst I agree, you could save a couple of hundred going that way, I still think you can pick up some bargain converted cars so it becomes difficult to consider the conversion especially if starting with a bog standard car
For sure! Only worry with that is what abuse has the car been through, but I guess if all checks out why not!
The only reason im looking at low boosting mine is iv owned it since March and probably owes me about £5000 now after getting Cambelt, dephaser and water pump done.
Also had all the gaskets and some wiring changed
New brakes with RC6 pads
Whiteline RARB
New gearbox seals
New driveshafts
PMS top mounts and brace
Braided hoses
So would preferably like to stick with this one now.
  Range Rover Sport
I wouldn't bother.
Can you give me an example of a £5000 turbo car that will handle as good as a well set up cup and be a fair amount quicker?
Bar a 225 variant...
Buying a turbo converted cup kind of defeats the object of keeping his well set up cup that he's just spent ££££ on.
  172 Turbo
5k, 236bhp, Quaife, B14s, all suspension bushes uprated, belts done.
Sell the Cup and it's less than the cost of the turbo conversion.
It's never a good idea to spend the money yourself on a car worth £1500-2000
  Range Rover Sport
But that's not a cup? I think either way the OP has in mind he will lose some money if he has the conversion or buys another car.
Kind of going off topic slightly though.
