Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
182 temp gauge issue
Discussion in 'Scotland' started by Sean182inferon, Apr 6, 2017.
  1. Sean182inferon
    Sean182inferon
    Feb 23, 2017
    13
    Car:
    05 Clio 182 inferno
    Sorry to bring up a well known issue however I'll puzzle about This one , when I start my car the gauge appears to be working as normal it'll creep up , then when I drive off it seems to sit a tad lower/cooler that normally will occasionally drop the slightest ( I mean minascule) then it'll Creep up but if I stop it'll heat up to operating temp ? Plugged in the code reader and it's giving me nothing code wise does anyone know what sorta values I should be getting from the temp sensor I could use the live data to rule it out ? Or is this common of the thermostat to produce such fault ??
  2. james24785
    james24785 ClioSport Moderator
    Mar 30, 2003
    5,606
    Stoke on Trent
    Car:
    E46 M3
    New thermostat time I rekkon. Might aswell chuck a temperature sensor on at same time
    Sean182inferon and imprezaworks like this.
  3. Sean182inferon
    Sean182inferon
    Feb 23, 2017
    13
    Car:
    05 Clio 182 inferno
    Yup I think your right heaters aren't as good as they usually are , plus when am sitting idleing the water pump won't be spinning as fast as when driving so explains why it heats up when sitting , should I just buy off Renault ? Or Is there any aftermarts that are better the OME
  4. james24785
    Mar 30, 2003
    5,606
    Stoke on Trent
    Car:
    E46 M3
    I'd imagine they're cheap enough direct from Renault mate
  5. JamesBryan
    JamesBryan ClioSport Club Member
    Feb 12, 2009
    6,876
    Warrington
    Car:
    Titanium 182
    Part no: 8200772985
    About £37 from Renault with a new seal.
    You'll need Type D coolant too.
    Sean182inferon and james24785 like this.
  6. Sean182inferon
    Sean182inferon
    Feb 23, 2017
    13
    Car:
    05 Clio 182 inferno
    Cheers bud already got irn ordered and got a temp sensor while am At it how ever the gauge seems to be working fine again lol
  • Share This Page
