Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Bilstein B14 different spring rate... Faulkner
Discussion in 'Suspension, Brakes, Wheels, & Tyres' started by incy-spider, Apr 21, 2017.
  1. incy-spider
    incy-spider
    Dec 17, 2010
    1,090
    Barnstaple, Devon
    Car:
    clio 182
    Hi guys, has anyone played with different spring rates on there B14's on Clio 182?
    Looking into getting something slightly stiffer, think standard are 300lb from a quick search on here, have been recommended 400lb by @NorthloopCup in the past. Thinking either that or something midway to keep it more roadworthy...
    It's mainly for the Ring so I know it's only a slight amount I need to change the rate just to stop going spring bound on the carousel!
    Basically I'm after this info, without having to strip mine and measure up for Faulkner to supply a quote...
    For us to quote we require the following
    Spring open length mm
    Spring rates as quoted
    Spring travel = mm
    i.d. = mm
    o.d. = mm if critical
    spring end finish
    Best Regards
    Peter Faulkner
    Anyone know? Many thanks
  2. ed55j
    ed55j
    Mar 19, 2009
    696
    N Shropshire
    Car:
    172 Cup
    I had Faulkner springs on the b14s but I went with a longer and softer spring think it was 250lb. Perfect for the road.
  3. NorthloopCup
    NorthloopCup ClioSport Moderator
    Feb 8, 2011
    8,063
    TMR HQ Lichfield
    Car:
    Alien Green 200
    @incy-spider your tag didn't work for me for some reason? If you do it on tapatalk, it doesn't notify me for some reason?!
    Right spring length is easy! They'll either be 8" or 9" long springs. Easier to jack your car up and measure the spring length on full droop.
    Don't bother with the rest of it though as it's almost all b****cks. Lol! The front springs will likely be a 60mm/2.5" id on the bilsteins - most coilovers are tbh.
    Outer diameter - not important
    Spring travel - not important
    Spring end finish - should be classed as profiled. This means that they're flattened off to sit on the perch better.
    incy-spider likes this.
  4. incy-spider
    incy-spider
    Dec 17, 2010
    1,090
    Barnstaple, Devon
    Car:
    clio 182
    Legend! Thanks mate, do you think 350lb would be a noticeable difference, worthwhile? don't really want to upset the balance too much and start having to change the rears...
  5. NorthloopCup
    Feb 8, 2011
    8,063
    TMR HQ Lichfield
    Car:
    Alien Green 200
    Er, just looked on kam racings site, and they quote the rates as 400 fronts and 285 rear!!
    Up the fronts to 425 or 450 mate is my advice after reading that. You'll not upset the valving in the dampers doing it that way either. A 25lb increase might not sound much, but it would be noticeable.
  6. incy-spider
    incy-spider
    Dec 17, 2010
    1,090
    Barnstaple, Devon
    Car:
    clio 182
    Ah okay! Don't know where I found 300lb from then, depending on price I may order a few options...
  7. NorthloopCup
    Feb 8, 2011
    8,063
    TMR HQ Lichfield
    Car:
    Alien Green 200
    Well kw v2's are 336lb fronts and i was quite surprised to read that the bilsteins are 400!
    They're not that expensive from Faulkner, so it's not a bad idea tbf mate
  8. incy-spider
    incy-spider
    Dec 17, 2010
    1,090
    Barnstaple, Devon
    Car:
    clio 182
    Maybe kw have harder shocks?
    I may message KAM and make sure they are certain with their info
  9. NorthloopCup
    Feb 8, 2011
    8,063
    TMR HQ Lichfield
    Car:
    Alien Green 200
    Kw use Koni adjustables mate.
    It's worth an ask mate, but I'm sure I've read it before that they're 400lb now I've had time to think about it.
  10. incy-spider
    incy-spider
    Dec 17, 2010
    1,090
    Barnstaple, Devon
    Car:
    clio 182
    Cool! Thanks mate
    NorthloopCup likes this.
  11. Tuffty172
    Tuffty172 ClioSport Club Member
    Jun 22, 2013
    79
    Whitley Bay
    Car:
    Clio 172, Shogun
    Did you get different springs for your B14s, was looking up stiffen mine on my 172, has it affected the handling ,
  • Share This Page
