DIGITAL CLOCKS
WILL ASTRA GTE DIGITAL CLOCKS GO IN A 16V CLIO IF YOU HAVE THE GEARBOX TRANSDUCER AND LOOM, I HAVE HEARD OF THIS WORKING BUT JUST WONDERING IF ANY1 AS ANY IDEA
I should imagine itll work, the only problem youll have is the speedo drive in the gearbox.
Or if you can make something so that the transducer will fit the clio speedo drive.
Its only 3 wires that go to the transducer to the speedo, so you dont need the loom, just make sure youve got the plugs and transducer for that set of clocks, because theyre callibrated for each car.
I might even have the wiring diagram with the colours of which wires to connect to for all the lights and dials.
Im pretty sure youll be able to get them to fit.
Most of the instrument panels plastic, so you should be able to chopp it up a bit.
Send some pictures when its all done.
