Doing/Clunk at end of reverse?
  Mec 350 slk manual
And if the little screw is not flush, the wheel will not seat correctly, however tight you do the 4 wheel bolts up.
Top mounts?
Just replace them with new.
Yer that happend on mine nearly lost the front wheels because of the screw on the discs
  Astra
Except if they're dragging a bit they do it anyway. Can you wiggle the pads back and forth in the calliper?
I looked at both sides with wheels off and all 4 ends sit snugly on their calliper edges, can't see how they would move up/down as there is no gap for them to move into!!!
