Earth point in boot?
  Clio 1.4 dynamique
I've installed a powered subwoofer today and use the bolt that secures the hooks behind brake lights, are there any other earth points in the boot that will hide my wired better?clio mk 3
Also, really daft question but I removed the lower door trim to run my cables under from head unit to the boot....cannot for the life of me get them to clip back on properly lol ( got a small gap between the trim and carpet) is there an art to it or am I just being simple?
Pauleds
  Merc Dueliner sport
There are 2 proper earthing nuts (one either side) behind the rear boot plastic trim that the rear light earth's go to.
  Clio 182
When i had my clio i sanded boot pan and bolted through it, then silicone underneath - not sure if it was pikey but worked [emoji1360]
  monaco 172
Not pikey at all, I would always suggest sanding to fresh metal and securing with a nut and bolt. Then hammerite from the underside once secure.
