NOS
NOS or Nitrous Oxide is a great way to add more power to an N/A engine. NOS is perfectly legal to use in this country and has been fitted to several performance cars including the CTR. Even Top Gear got in on the act fitting it to an old JAG.
So before talking about the systems available I had better explain what it is:
It is actually quite a simple principle really as you all know add oxygen to a fire and it will burn brighter and hotter and at the same time consume more fuel. Remember, fuel makes power, nitrous simply lets you burn more of it. By giving the engine more oxygen to burn than can be got through the cold air intake. More fuel burning means more power typically about an extra 100Bhp. Obviously this can only be maintained for a short period of time due to needing a seperate supply of NOS.
So now onto the different systems available:
Nitros Systems
These are three basic types of nitrous systems: dry, wet, and direct port. The most misunderstood is the "dry" type of system. A "dry" nitrous system simply means that the fuel required to make additional power with nitrous will be introduced through the fuel injectors. This keeps the upper intake dry of fuel. We accomplish this by two methods. First, is to increase the pressure to the injectors by applying nitrous pressure from the solenoid assembly when the system is activated. This causes an increase in fuel flow just like turning up the pressure on your garden hose from 1/2 to full. The second way we can add the required fuel is to increase the time the fuel injector stays on. This is accomplished by changing what the computer sees, basically tricking the computer into adding the required fuel. In either case, once the fuel has been added, the nitrous can be introduced to burn the supplemental fuel and generate additional power.
The second type of nitrous kit is the "wet" style of kit. These kits include carburetor plate systems and add nitrous and fuel at the same time and place (normally 3-4" ahead of the throttle body for fuel injected applications or just under the carb as with plate systems). This type of system will make the upper intake wet with fuel. These systems are best used with intakes designed for wet flow and turbo/supercharged applications.
The last type of system is the direct port system. Just as its name implies, it introduces the nitrous and fuel directly into each intake port on an engine. These systems will normally add the nitrous and fuel together through a fogger nozzle or a NOSzleTM. The fogger nozzle mixes and meters the nitrous and fuel delivered to each cylinder. This is the most powerful and one of the most accurate type of systems. This is due to the placement of the nozzle in each runner, as well as the ability to use more and higher capacity solenoid valves. A direct port system will have a distribution block and solenoid assembly which delivers the nitrous and fuel to the nozzles by way of connecting tubes. Because each cylinder has a specific nozzle and jetting (both nitrous and fuel), it is possible to control the nitrous/fuel ratio for one cylinder without changing that of the other cylinders. These systems are also one of the more complicated systems when installation is considered, as the intake must be drilled, tapped, and the "plumbing" made to clear any existing obstructions. Because of this and the high output of these systems, they are most often used on racing vehicles built for the strain of such high horsepower levels.
So any Clios out there with NOS? As you can see once you have chosen the system you want to use fittmenmt is actually quite easy, but on saftey grounds is probably better left to someone who knows what they are doing unlike me!!!
Rich-D
  E90 LCI 330d
Quote: Originally posted by jezyg on 24 November 2003
NOS is perfectly legal to use in this country full.
Really?!
AFAIK it was illegal...
Tom
  EV (s)
There are reasons why it could be illegal and reasons why it isnt.
Its a bit of a grey area
KDF
  Audi TT Stronic
^^ what I thought,
although I thought its legal to carry in the car (with nos sticker or warning sticker) but the illegal bit is actually using the nos in the engine.
No one has yet been prosecuted but you are right you are not suppose to use it on a public road, but the problem is how do you detect someone is using it?
Which is why it can be fitted legally!!!
Just put it down to our rather silly laws:D
MaLicE
Honorary Member
  Lazy v8
it is legal to use it, as some manufacturers are putting on there cars as an option list i.e the mg x power thingy.
it is legal because its not a fuel, it is illegal however to use more than 1 fuel on the road at 1 time, nos is an oxidizer (iirc) and just makes the fuel burn quicker.
if you were to be stopped they cant do sh*t about it as its not illegal, if u go to the wizards of nos site it explaines why its not illegal etc...
There is no law stating that you can be charged directly for having nitrous in the car. They might be able to charge you with related driving offences though.
