xenon problem!!
  clio sport 172
hi, last month i decided to change the xenon bulbs on my 172 sport. after i put them in the drivers side decided not to work for some reason and when u hit the unit it would flicker and go off again. i assumed it was the ballast pack causing this so today me and a mate put the new ballast on and it worked for a couple of seconds then went off,when i took the bulb out it had broke in half!! could this problem be the ignitor?? iv'e just ordered another 1 off renparts. both ballasts work fine and the other ignitor works fine. any advice would be a help as its turning into an expensive pi** about! thanks
  www.renparts.co.uk
swop the parts over from one headlight to the other to see if it swops the problem. Have you bought the ballast on ebay?
  clio sport 172
hi,yeah i swopped them over the other ignitor/bulb works fine so im sure its the ignitor. yes i got the ballast off ebay and i've just ordered a ignitor from your ebay shop.cheers
