Limp mode check injection
  Mk3 clio 1.2 turbo
I have a mk3 clio 1.2 tce, it goes into limp mode and a warning light appears saying check injection. Ive had it plugged in and its bringing up multiple misfire and was told to change the coil pack and nothing changed, any help would be appreciated.
  Mk3 clio 1.2 turbo
You need to get it diagnosed. Someone telling you to change a Coil pack, won't necessarily fix it. What cylinder is it misfiring on?.
Iv had the coil pack changed as my brakedown mechanic said it needed changing because it brought up multiple misfires on the code.
  Mk3 clio 1.2 turbo
I have check to see what codes come up and its P0300 random/multiple cylinder misfire with the check injection on the dash i have had a new coil pack put on it and checked the spark plugs and they are clean, would it be wise to change the injectors?
