Big Steve's RB Clio 182 Cup Restoration
DomP182
  ph1 172, Arctic182
Steve when you dropped the fuel tank did you have much of an issue with the bolts? What size and thread are they, I think I'll put some stainless in their place
Big_Steve_T
It’s no bother sir.. just try to make sure you’re dropping the tank when it’s low on fuel, no fun trying to do it when it’s got a full tank of Fuel.
  1. Wrestle off one of the the one-time jubilee clips that are holding the filler feed and to the tank. Once you get it off, disconnect it and then also undo the fuel tank overflow/breather line as well. Now the remove the fuel filler neck. (Don’t forget the two tor’s screws under the fuel filler cap)
  2. Get in the car and lift up the back seats, to find the dinner plate sized plastic cover for the fuel pump/tank sender unit. Pull the plastic cover up and then un-plug the electrical connection to the tank sender unit. Whilst you’re there, its easy at this point to also disconnect the fuel feed, just push the little tab on the side of the connector whilst pushing the connector against the tank (to allow the latch to come undone) then you should be able to pull it off. There will be a little bit of fuel spilled here, so have some blue-roll/rags ready to mop up.
  3. Get a jack under the fuel tank (with a piece of wood inbetween the tank and the jack) to take the weight of the tank, and then get your 13mm socket wrench and undo the 4 bolts that hold the tank to the car. I’m sure if it’s never been off, some of them will fight you, I always try to undo it, then if it starts to get tight, do it back up a turn or two, then continue to undo it.
  4. When the bolts are undone, you can carefully lower the tank with the jack. At this point you’ll notice that the vapour return connection becomes visible, again same process as the fuel sender line, push the tab on the side and disconnect.
  5. Now you can fully remove the tank from the car
As for re-fitting, yeah a few M8 x 30mm Stainless Flanged Bolts with bigger penny washers will so back in a treat, and not rust on you, like the bloody OE Renault fastenings will..
DomP182
  ph1 172, Arctic182
Thanks! That's a good write up there Steve, unfortunately I've got around 1/2 a tank full due to lockdown🙁 1.5mm thread I presume?
botfch
  Clio 182
Well that didn’t take a lot of work...
Removed the passenger side headlight, pulled the 4 small relays out and checked the connections all looked clean.. and then put them back in, and it bloody started first time!! 🙄
So now the engine’s running, I had a very successful evening bleeding the brakes, and then fitting the exhaust:
Don’t think I’ve ever had an exhaust go on a car so easily and so tightly (fitting!)
Thanks for reading 🙂
Typical Renault. :ROFLMAO:
I’ve just bought clip to fix an annoying issue on mine which has now apparently fixed itself..
Big_Steve_T
A beautiful sunny day fiddling with the front of the car today. 🌞
New grille prepped for fitting, need to drill the hole for the bonnet switch as they don’t come pre-drilled. 🤷🏼‍♂️ Old one was looking very sorry for itself, and had a few knocks:
Next I dismantled everything from the front bumper to be cleaned:
Whilst I fitted the obligatory Skoda Fabia front Splitter:
I then removed the GASH front bonnet badge that had been crinkle painted (like all the badges on this car) to replace it with a nice new shmoo OE one:
Finished off with a front bumper looking very pleased for itself:
Ordered new fog lights tonight, so when they arrive, I’ll be able to get them onto the car, but before then, I think I’m going to pay a little homage to my R5 GT Turbo Raider with the Fogs... 💛
Thanks for reading 😎
DomP182
  ph1 172, Arctic182
@big_fuel tank removal guide worked a treat thanks! On reassembly did you replace the foam tank pad, the black plastic outer casing on mine is perished
Big_Steve_T
Managed to rope in my dear wife for an hours "Covid-19 Car Crafting" ;) one evening this week to get the Fog Lights covered in Yellow Vinyl:
Chuffed with the final result, and how they look in the finished bumper:
I know they might not be to everyone's taste, but I love the nod it gives to the car's grandfather (my 5GT Turbo Raider) If i decide to go back to the clear lenses, it's only 10 minutes work to peel off the vinyl??
In other news, I'm struggling to get the car started at the moment. Initially I wiggled the relay box and it started up, so thought the problem was a duff connection in the engine bay... but after no end of wiggling yesterday, I still can't coax a spark out of the coil pack..? I've now traced that the TDC sensor is open circuit, so ordered a new one of those..
#bl**dyrenaults!
Thanks for reading :cool:
Big_Steve_T
To have a break from the Clio today, I pulled my 5GT Turbo Raider out of the garage and let it idle for a good while to fully heat up:
I was pleased that even though it had been covered in all sorts of crap, it hadn't picked up any damage. I then decided I wanted to re-fit the original Raider wheels and tyres, so I nipped out to pick them up from storage, and then jacked the car up to fit them.
As I've just had a load of brake fluid delivered for the RB Clio project, I thought I would take the chance to change the brake fluid on the Raider, as it's been in there for a good number of years now.. So it was a wheel change, and brake fluid flush & change:
Next thing I want to do is flush & change the Coolant, before I then also change the oil.
DomP182
  ph1 172, Arctic182
Hi @DomP182 ,
Interesting you ask that question, I measured the positions bushes in the rear beam accurately before I removed them, and gave the accurate dimensions to the garage who pressed the new bushes in for reference.
When it came to fitting the rear beam back onto the car, I did all of the nuts up until there was only 2/3mm of movement and found that I couldn’t move the beam left to right across the car, but found I could move it from front to back. So I just pushed the beam towards the FRONT of the car in the centre to equalise any tolerance that might be present (and hopefully stop the beam going on skewed...
At the end of the day it’s a mass produced super mini with a bigger engine, so I don’t think it’s worth getting too hung up on it, no doubt Claude didn’t when he put it on at the factory... 😆
Dont suppose you have the measurement for the distance the beam bushes press in Steve?
DomP182
  ph1 172, Arctic182
@Big_Steve_T I'm about to fit febi beam bushes using your measurements, because they dont go tight up to the beam what is to stop the beam moving on the mounts?
DomP182
  ph1 172, Arctic182
Holy crap they arent going in easily, I've made a press from 10mm threaded bar, an old caliper piston with a hole drilled in the end and a big socket but it's not budging once it's got to the taper on the bush. In the freezer for the night!
Big_Steve_T
Phoned up my local Renault parts guy:
"Hello Paul, can you still get hold of the original 205110 paint for the wheels on my Clio 182 Cup?"
"Yeah sure, I'll order you a tin"
🤦‍♂️:poop: Bugger!
So I've dropped off the wheels with a local refurbishment place, and they're now going to colour match the OE paint, and get them painted up for me:
