DJ Kaled , Another one 🙈🙈🙈. Track car
finch wxm
  clio 172
Master cylinder fitted and lines installed
Rear number plate light , boot latch and boot seal fitted.
finch wxm
  clio 172
Need some time work really to get this built , i am waiting on some parts from powder coaters ! Unfortunately they take forever to do anything.
Engine and gaearbox will fitted as soon my gearbox mounts are ready.
finch wxm
  clio 172
Removed the aircon from the heater box tonight and got the heater matrix bolted in place , can make a start on fitting the interior loom and dash into the car.
The hole that needs to be filled 😂
Heater matrix bolted up, will have to put some rivnuts in possibly at the top.
finch wxm
  clio 172
Today was the day to get the flywheel , clutch and engine and geaebox fitted as the mrs started back at work so i get a full saturday in the garage 😂.
First thing was to make some space and get the garage cleared and the clio pushed back as far as possible to give some clearance height from the front garage door being open.
finch wxm
  clio 172
Engine and gearbox ready to go in.
Finally in position , will have abit more room now ! Can finish stripping whats left on the iceberg , need the drivers door and glass from the doors unless i go poly windows.
Looks like ive done something but this car was a bare shell , no fuel lines , no brake lines , no wiring looms etc plus the other build and lack of time but happy its in !
Painted the bolts after it was fitted as the pink bolt was annoying me 😂
Forgot to install the water pump pulley as it had been put away then i noticed it was bright 🍊😳😳🙈🙈
finch wxm
  clio 172
Still undecided whether to fit a brand new set of cup shocks and a new set of springs , maybe the grams or something else or do i just get some BC Coilovers for the car ? 🤔
finch wxm
  clio 172
This saturdays activities passeger side driveshaft and abs ring and braided line to caliper and hardline to abs unit.
Re-fitted abs to this car For a direct comparison to the red but this will be mainly be a road car / wet trackday car.
Half the battle is having to make space to work in the garage at the moment.
Thats passenger side done onto the next.
finch wxm
  clio 172
Master cylinder fitted and fluid filled up to check for leaks on the lines and there was a leak ! Sorted now !
Injectors installed , ignition leads and coilpack fitted.
Radiator and hoses clipped up but have a new radiator on order.
Wiring loom next and electrical bits 🙈
finch wxm
  clio 172
Managed to get the seat subframe and slider fitted. Only have 1 seat for this at the moment . May buy another or just borrow one from the red clio as and when !
Abit snug but im a stone heavier afterna year of munching ! 😂😂
finch wxm
  clio 172
Need to install engine bay wiring loom , needs the looms from the iceberg shell for the doors and rear lights.
Need drivers door from iceberg and both glass unless i go for perspex windows 🤔.
What do people think ? Perspex or glass windows ?
Also have cage colour ? Whats peoples thoughts ?
finch wxm
  clio 172
Managed to get abit of time on the white clio today before the wales match. No comments on the result !
Test fitted the cage , need to get bolted in , bottom feet should be ok but might need to modify the rear strengthening plates.
finch wxm
  clio 172
Managed to get the car to start firstime !
Had a fuel leak ! Rubber o ring had seen better days ,luckily i had 2 connectors from ktec so just replaced o ring and all good.
Car was idling at 3000 rpm so likely a vacuum leak , put fresh gaskets and double checked inlets on refit. Idling was now around 1000 but seemed to be struggling and flashing on dash to indicate fault.
Swapped
Swapped pedal which removed one code.
finch wxm
  clio 172
Took my laptop and Rs tuner down tonight to see if i got any clearer codes and this is what i got , i'm hoping its coil pack rather than a wiring fault.
finch wxm
  clio 172
This is one hell of a build and a good read.
Can I ask where you got the cage from?
Thanks buddy its the guy on ebay , i just emailed him directly and paid him via paypal. I can send you his email address if you want to get in touch.
Need to get mine powder caoted once i sort the strengthening plates
