Hi , i have had a few issues with my front suspension recentley , i was getting a slight humming noise when steering sharp at right hand bends so i suspected front nearside bearing ,prior to that i have had new shocks,springs ,track rods and lower ball joints so today i had a new driveshaft and front wheel bearing fitted as a matter of course asthe car is aproaching 115k (1.5dci 05), however i took it for a good test drive and low and behold i am still getting the huming noise right hand down ,i didnt suspect the rear bearings as offside rear is less than 12months old and rear nearside was fitted august 09 as iremember excactly when it went on me.After a quick jack up of the car i spun the rear wheels and their is a slight rumble from rear nearside , if it is on its way its only done 15000 miles at most , it was a aftermarket bearing but is this normal as i dont carry passengers and a heavy load,i am hoping its the bearing as its a cheap fix but after going through all the new front suspension parts i am a bit annoyed that my problem could be a rear bearing with aprox 15k on it.
