Having trouble with airbag light... Recently changed the squib on a 2005 clio, put everything back together started up and the light was on... As if this car hasnt caused me enough grief!
Anyway i did turn the ignition on while the airbag was disconnected so thought this may have been the fault, plugged scanner into it and tried to clear the codes and they wouldnt clear.. So took everything apart to see if everything was fitted properly and it was but the light stays on
Any ideas? Dodgey squib?
