Alcantara cleaning
  Clio 182 trophy
Hi folks looking to clean ma alcantara seats after u spray the raceglaze cleaner do u use a dry or damp cloth to clean off cheers
"Raceglaze Alcantara Cleaner comes pre-diluted to the correct strength for safe use on all Alcantara surfaces, and should thus be used neat. For stain removal, we recommend that it is sprayed on to the affected area lightly and then agitated lightly using either a Raceglaze Leather Brush or a PB Utility Brush. This will produce a slightly foamy lather, which may discolour as any soiling is progressively released. The lather should be wiped away using a damp Atomiza Microfibre Work Towel, and the surface then left to dry naturally. For general cleaning duties, Raceglaze Alcantara Cleaner should be sprayed on lightly and then left to sit for 1-2 minutes before being wiped off using a damp Atomiza Microfibre Work Towel."
The internet is amazing. Should also say this on the back of the bottle... ;)
