anybody using optimax
filled up today at a shell and noticed the optimax so i put some in. :)
anybody been using this stuff with a 1.8 16v? is it any good?
  Was a Clio 1.8 16v
Yeah i filled mine up this week with the stuff after hearing Reno recommend a 97+ ron rating of fuel for the 16v engine.
Not to much different unless u fill up when ur tanks drip dry and then put it in, but that happens when using the normal stuff. I used to notice it a LOT in my 1.4 Mk1 Clio, but havnt with my 16v but then it feels faster some days rather than others anyway.
been lookin about on the net. supposed to be good stuff but you have to keep using it. i could do with a few more mpg from this thing.
lot of rave reviews ive seen
  Was a Clio 1.8 16v
Yeah its noticably better when using Optimax only it costs 80p a litre!
As for increasing MPG, forget it. It is better cause of the higher octane rating, which causes the fuel to burn quicker/easier, thatll just mean better accleration but should give same MPG really.
Mikey is wrong. EVO magazine, the GOD of automotive publications, did an in depth study on a Civic Type R, a Jag XJ8, and a Z3. In all cases it cleaned the engines whisper clean (except the BMW cause it was brand new), provided more reponse and slighly more power (especially in the mid range), and returned marginally better mpgs for all the cars (although the mpg results vary from car to car).
Definately the best fuel on the market at present
EVO! dont make me laugh, that bunch of muppets!
Anyway, will it affect performance?
Nope, you wont make any more power.
Why?
Higher octane fuels effectively burn SLOWER not faster, they go through PRE-flame changes slower thana lower octane fuel.
This allowes you to start the burn earlier so at TDC youhave the whoe mixture burning and you use all the pressure rise as efficiently as possible.
But since the 16V does not have any means to check octane rating, you wont benefit until you change the ignition curve to make use of the higer octane.
In my new clio i had to go to normal unleaded for a fill as there was no optimax, but filled it up at shell yesterday and its back to 1000%. Def a difference!
KDF
  Audi TT Stronic
Optimax is the dogs dangles.. and your lucky to get it at 80.0 its cost 82.9 where I am.. fcuking b*****d goverment overtaxing everything..
Ad
  MK2 FRS
I think you can relly notice the difference. The 1.2 16v seems much more smoother and responsive. I will have to see on the 172.
The only thing I have noticed is it seems a bit smoother and I get better MPG. But thats it, I never got my fish to acclerate like they do on the advert!
Paul
  Astra 1.9cdti XP
I get worse MPG with optimax, I must drive harder! Dont use it that much cos I dont think its worth the extra you pay for it.
  A SHED!
Optimax works! Ive noticed the difference. but like everything you just get used to the better response.
i used to use optimax all the time until my mate said he read an article about it, something to do with it making u burn my oil or something. cant remeber the details of it. have a search on the net about it.
  Nissan R35 GT-R
BenR: Higher octane fuels do NOT burn slower, they burn just as fast as plain unleaded once a definate spark comes along.
  Was a Clio 1.8 16v
The 172 requires 97+ ron fuel does it not?
BTW i know its safe to use 95 ron, but Reno say so!
Can someone explain why it would improve MPG 4 me? Cheers.
Its VERY unlikely you will feel any difference by putting in Optimax as opposed to Super or normal unleaded.
You only think you feel more power / responce is because you are expecting it.
The higher RON rating suits jap cars where there ECU are programed for 100+ron which is available straight out of the pump over there, and a must for turbod cars running higher boost than stock (helps prevent detination)
It makes me chuckle when I see posts like these with people claiming they can feel a big difference after putting in optimax.
KDF
  Audi TT Stronic
Renualt recommend 97+ RON .. i thought who am I to agrue, they certainly arent benifiting from me paying more on fuel.
I have never run my car on normal unleaded so I couldnt say if there is a difference.
Super Unl is 97+.
I have to use Optimax and octane booster at every fill up on my Soop because its an import and the ECU is mapped for 100RON. If I run it on normal unleaded at the boost Im running it will destroy the engine.
  Nissan R35 GT-R
Quote: Originally posted by Barryd on 03 April 2003
Super Unl is 97+.
Better safe than sorry mate.
well cheers for the replys guys. for an extra £1 at a full tank ill use it!
its all down to mind over matter. if david blane can float above the ground surely i can manage a few extra mpg :)
KDF
  Audi TT Stronic
as far as I was aware the theory behind the extra mpg is that you dont have to put you foot on the throttle quite as much to maintain a certain speed hence using less pertrol hence more mpg.
  BMW 320d Sport
LOL BenR I better get the flags out! For once I entirely agree with everything you said in your post, and you almost took the words out of my mouth. Forget Evo, theyre just a rich boys club who like to call each other by their surnames just like when they were all at Eton together. I emailed SHELL when Optimax first came out and questioned them on it and they admitted that on a non-adaptive ECU like on the old 16v the only benefit that Optimax would have were the advanced detergents they use. In other words it will keep your engine clean and tip top but thats it. On modern cars, 172s etc the ECU can adjust the ignition for higher octane, advancing the ignition for more power because the higher the octane, the more resistant to knock it is, and the SLOWER it burns. Not much point firing a mixture early if the burn if finished before you even get to TDC! The point is you get a longer more sustained burn which keeps the pressure up on the piston for longer hence more torque out of each cylinder.
Sheesh, if you wanna get technical......i said they burn slower as most people wouldnt really get the gist if i purely said that they dont go through actual compbustion slower, but pre flame reactions slower. Thus reducing the cahnce for spotaneous combustion (detonation).
So, since they do go through pre flame reactions slower, one a definate spark comes alone, the time for a complete burn and presure rise takes longer than on a lower octane fuel
Happy now?
  clio williams, Ph1 172
I dont really notice any difference to be honest but then again its only slightly higher octane isnt it. Not like some form of Rocket fuel! lol.
I think mine seemed to use it quicker though. But then again my car is sh*te on fuel like all the time!
  Nissan R35 GT-R
Happy now?
Hey I wasnt having a pop or stating you are wrong, just pointing something out. Its a discussion forum at the end of the day, so dont be suprised that someone replies to a post of yours. I agree with what you said as usual, but wanted to add a small detail.
  Nissan R35 GT-R
Cool.
Interestingly, has anyone been on to the Optimax forum? Theres a bit called ask the expert, the only thing is, no expert has answered any question that has been posted there! :D
The handbook for the 1995 Clio recommends the use of 95 or 98ron fuel - but that certainly doesnt say anything about Optimax! As I understand it, the 16v ECU will change the settings to accomodate either 95 or 98ron and so no difference will be noticeable.
I use a good quality fuel whenever I can - and in Bristol that happens to be Optimax. I can confirm that Optimax makes absolutely no difference wahtsoever to the performance of my 16v. But, if were going on the psychological argument, Im not expecting anything, so Id not notice it anyway. ;)
