battery disconnect
DaveDreads
Remove the negative first, then the positive, undo the battery clamp, lift it out job done.
If you're leaving the battery in place, wrap the ends in gaffa tape. (metal bits at the end of the wires)
You don't want them touching the battery and shorting out and causing a fire.
  Renault clio 04
didnt see your edit, thanks for the advice
DaveDreads
You can have the battery disconnected indefinitely pretty much,
it wont affect anything, other than your dash clock & stereo pre-sets.
Obviously your alarm & immobiliser wont work, but it's not like anyone can steal the car without a battery in it. ;)
