I suppose this is a solution...
For those that have fitted a fire extinguisher system (pull cable and 6mm tube), what is the best location/route through the bulk head. I want the pull cable to be above the driver side.
I have lifted off the scuttle panel and can see the air blower, to the left there is a large area which im guessing would lead to the part behind the dash, however im not removing the dash, so want it to be visible below it. It seems that it is to high or otherwise I could have drilled straight though that and under the dash.
Any ideas guys (or is it a dash out job).
Thanks in advance
Thanks in advance
