Brake fluid
  Clio Cup Ph2 172 16v
My clio 172 cup recently (couple months ago) had the brakes bled and new rear calipers fitted to pass MOT. Can anyone tell me if the brake fluid is changed when bleeding the brakes? If not I think I will change the fluid, am I right in saying 1000ml is enough?
Thanks,Aaron
When u change calipers they always bleed them so there is no air in the system.. Weather they changed the fluid you will have to ask the garage.. A 1litre bottle of fluid will be fine if you do change the fluid
