Brake pads - which ones and how much
Ok then my front brake pads are knackered so which ones would you recommend getting and how much are they. Or should i stick with some cheap pads as its only an RT so doesnt have loads of power.
std...........cheapest........
unless you have the profound ability to get them to fade on the rd in a RT.......
if you can, i suggest learning to use the brakes less........you shouldnt have any problems with the std setup.
Thats what i was thinking realy ben, i may drive a little rapid some times but dont think expensive pads will help much realy tho. Just wanted some oppinions first tho. How much are standard ones? i saw some on eurocarparts for £12. bargain?
