Brembo brakes
  Arctic Blue FF 182
Might not be of any use, but do you know if the pins are the same as the Megane brembo's? If so there is a guy on the Megane forum who sells the modified pins to stop them corroding in as much I believe.
Jaff.
I don't, I know they're the same as the ford RS though. Thanks for the info tho, will see if I can find out if their the same
Jaff.
Good to know. Might order the ones linked now then.
Was looking grim at one point when the only kit I could find we're nearly £80 each
