Brembo HC Disc defect?
Hey,
I had my discs fitted at Fred's just over a year ago, and I've noticed a few days ago the drivers front disc has a 5-10p pence size of the surface just completely disappeared, it goes back ~2-3mm - is this a defect?
Also, what sort of warranty do the Brembo discs cover?
I'll get some pics up tonight!
Pretty sure this isn't normal?
  Mk1 MX-5 (x3), Westy
Pic would be good - mine did have a dimple a few mm deep (wear marker, I presume) but it was only about 6-8mm across.
Hmm ok!
Well I'll get some pics up ~6 ish and then we can determine if it's normal, I wouldn't have said so though as when I was quickly looking I only saw it on one disc (unless the other one was behind the caliper at that moment).
  Inferno 182 & Saxo
always worth keeping an eye on them every so often - OP how many miles did your set do and under what conditions?
