Fortunately I can probably reuse the old one.
It must be worth its weight in gold!
Anyone ever tried using silicon?
the oil seperator dosn't no.Still havent had a previous question answered. If you unbolt the oil seperator cover does it interfere with the cams?
Yes they want to be clean. Run a bead round the edges to seal and let the seperator cover squish it out.Do you have to clean the mating surfaces with anything before you apply the silicone gasket..like some WD40?, also should i put the silicone gasket on then spread it out into a thin layer before i tighten the cover?
