Can I use normal household silicone on exhaust joints?
Paddy_g46
Juts wondering if it will hold up to the temps? I will be using it post-cat so shouldn't cause problems for the 02 sensors. Anyone done this before? Only asking because I went into halfords earlier and they didn't stock any high temp stuff.
Patrick
Exhaust putty - gungum is what you need, little round tins. If you know someone with a trade card get them to get it as its only around 40p on trade but £4ish normal sale.
Normal silicone will just melt and slide off...if it doesnt catch fire before that.
Paddy_g46
from my experience and others I have heard, gungum is s**t! Just goes brittle and breaks off.
Hi temp silicone will be fine.
Yeah but im asking if normal silicone will be good enough?
  Passat 170 DSG Wagon
They do sell it. Get the Loctite silicone, goes to 350c IIRC. I use that and it's spot on.
nup
  clio 172
I wouldn't use "normal household silicone " it will probably stink when it gets hot... If you are using a good quatily new system you don't normally need anything. If your trying to seal a leak then there are lots of better stuff to use - wait until you can get one of these.
Cro
  Meg'd r27
Loctite 7920 gasket/flange sealant is what you want. Its an orange colour, and gives a bit of flex at the joint. the putty stuff will break and fall off within miles
  Lionel Richie
NO, just NO, the worst thing you could ever use
DrR
  VW Golf GTD
I went o Halfords, Focus, B&Q, charlies, and tesco, none of them sold this high temp sealant, annoyed arg.
  monaco 172
I used some black loctite stuff from halfrauds and it was fine.
Fire putty is shite, just goes hard and falls off
  Ph1 Clio V6, Ph2 172
Ive used it for years on spring held joints and it works fine. I'm a plumber so have loads kicking around. Ive used it to join the collector box to the silencer on my vee which gets very hot after a good drive. 18 months later and not a blow on it. It doesn't melt or catch fire like some believe thats for sure.
As for gumgum, utter sh1te comes to mind. Infact, there's bugger all in halfords good for sealing exhausts.
