Spec is:
Full engine rebuild
I removed most of the old wiring, and ecu (renault siemens)
It now just runs an omex 600 with pre-assembled loom
Car cranks on ignition and the pump primes but will not fire up?
Injectors have got 12 volts on ignition 2 and when cranking (both sides)
Coil has 12 volts on ignition 2 and when cranking
All of the sensors are wired up as per 600 manual
Thoughts?
P.s I got a bit of paint on the fly wheel (about 3inches long) when I painted the block (with hammerite) could this affect the cps?
Full engine rebuild
Thoughts?
