That is a main bearing not a big end. I would change it simply because it's apart
As every body is saying I would change the bearings as they are already out, but to give you an insight of bearing failures follow the link.
http://www.engineparts.com/publications/CL77-3-402.pdf
that look like the main behind the flywheel? nothing too out of the ordinary for (i would estimate) 60,000 km?
christ i've impressed even myself with that one! LOL
yes, sounds like you thrust bearing is shot, luckily you can get oversized thrust washers/bearings
are you running a monster clutch or anything?
