Clio s1600
The s1600 clio is pushing 220bhp. Can anyone find a spec sheet for this car? I had one but seemed to have lost it in the depths of google.
Any help much apprec
sorry ben, its not what i thought it was but here is what I found
Engine
No. cylinder
4
CC (x1.7 if turbocharged)
1598
Bore / Stroke (mm)
79.5 / 80.5
Comp. Ratio
Max.Power (bhp)
220
Revs.
8600
Max.Torque (kg/m)
20
Revs.
7000
Turbo
no turbo
No. Valves
16
No. + Position Cams
2 Overhead Camshaft
Location
Front-Transverse
Transmission
Location
Front-wheel drive
Differential (Front-Central-Rear)
Mechanical
Clutch
single
Gearbox
6 speed sequential (Sadev)
Brakes
Front / gravel
DV285
Front / asphalt
DV355
Rear / gravel
DV265
Rear / asphalt
DV265
Suspension (shock absorbers)
Front
MacPherson
Rear
Trailing arm & coil over damper
Dimensions
Length (mm)
3833
Widht (mm)
1782
Height (mm)
Wheelbase (mm)
2495
Front track (mm)
Rear track (mm)
Weight (kg)
950
Told you!
it does have a single throttle body and the inlet is restricted to 60mm. Originally you had the choice of one throttle body per cylinder by restricted to 40mm, or the single inlet retricted to 60mm. Citroens saxo was the only team to use the 4x40mm throttle bodies and subsequently took the chanpionship by storm. Sebastien Loeb won and they banned teh 4x40mm and you can only use the 1x60mm inlet retrictor now. However, this just handed the saxo more torque becasue it didnt reduce airflow any more and upped the airspeed. It realy is an amazing series to watch, and 220BHP aint too much in teh racing world, without the restrictors, they could probably make 300BHP at 200BHP/ltr.
