Compatible gearboxes
  Clio Sport ph1
Which models(megane,laguna) has the same gearbox like mine Clio PH1 - JC5 089 ?
Please, write direct specifications of cars including year of manufactured and engines.
Thank you very much, I have to replace my broken gearbox, so this is the cheapest and fastest way, how to fix that.
  Ph1 track 172
CHEAPEST way to get your car going again would be to use a JB3 box with a mk1 mount,
could pick one up for around £50
  Clio Sport ph1
Fred: it is not true, because not all JC5 has the same ration. I need just JC5 089 - this one have been used in PH1 Sport.
  Golf GTD Mk7
ratio's are different yes, but they will still work fine. ph1/ph2 ratio's aren't that different. In fact i'm sure it's only the final drive that varies (might be wrong though :)). I think what fred is saying is that the ratio box you have is specific to the ph1. No other renault use that same spec, but the housing will be the same.
  Clio Williams
Download my Renault Gearboxes software and you can easily compare the ratio of different JC5 gearboxes:
  Clio Williams
Yes, it's Hungarian. Here is a quick translation:
Main page:
Alapjárati motorfordulat: Idle speed
Legnagyobb motorfordulat: Max. engine speed
Kerékméret: Wheel size
Váltó kiválasztása: Gearbox selection
Gyorskeresés: Fast search
Számolás: Calculation / Ok / Apply
Megnyitás: Open
Törlés: Delete
Egyedi áttétel: Custom ratio
Súgó: Help
Végáttétel: Final drive
Results page:
Névleges keréksugár: Rated wheel diameter
Dinamikus keréksugár: Dinamic wheel diameter (the software considers the dinamic tyre deflection)
Nyomatékmódosítás: Torque Conversion
Áttétel: Gear ratio (TC=1/gear ratio)
Össznyomatékmódosítás: Total Torque Conversion (current TC * Final drive)
Legnagyobb sebesség: Max speed (limited by the max engine speed), expressed in kmh
Differenciállmű: Differential
Mentés: Save
Megnyitás: Open
Törlés: Delete
NYomtatás: Print
Opciók: Options
Beállítások: Setup
Módosít: Modify
Újraszámol: Recalculate
