Clio 1.6 16V
Well, I said I would do it a while back when I discussed it online with BenR and have now Ive lived up to my words. Finished the install last night. Did some temp tests today when the ambient was about 24 degs (which is pretty hot for Scotland!). Put the temp sensor next to the door mirror sensor to calibrate against the car temp guage first then put the sensor inside the airbox. Did about a 20 mile run with a mix of 30mph and motorway 80mph ish and recorded average differential of about 2 degs against ambient. In stop-start traffic the differential was about 3 or 4 degs. Overall the engine feels much more responsive and has quitened down the induction roar .... can now hear my Magnex properly now!!
http://www.fifegallery.co.uk/domains/cliosport/coldair01.jpghttp://www.fifegallery.co.uk/domains/cliosport/coldair01.jpg
http://www.fifegallery.co.uk/domains/cliosport/coldair02.jpghttp://www.fifegallery.co.uk/domains/cliosport/coldair02.jpg
http://www.fifegallery.co.uk/domains/cliosport/coldair03.jpghttp://www.fifegallery.co.uk/domains/cliosport/coldair03.jpg
http://www.fifegallery.co.uk/domains/cliosport/coldair04.jpghttp://www.fifegallery.co.uk/domains/cliosport/coldair04.jpg
The air box is made from sections of 1mm mild steel braised together. The outside of the box is covered in self-adhesive heatshield material. The beading on the edges is the same as the strip that runs along the front of the bonnet, butting up against the underside of the bonnet, semi-sealing the air box. The air intake is part of a Pipercross 75mm ramair kit feeding directly from the lower grill to the air box (butterfly air valve removed for clearance). The box is held in place by two 10mm bolts so the whole lot can be removed in about 10 minutes if required. The wire you see on top of the box is my temporary temp sensor.
Next thing on the list now is the Unichip to get the fuelling sorted out.
