de cat question
  172 M69 eater
iv got a 1.2 clio and jus needed some advice.... the search keep stiming out on me.... sorry if someones asked before
if i fit a decat will it improve performance and will i need to put the cat back on for MOTs? iv already got an exhaust and a hillpower induction kit
anything else i can do to make it faster apart from fitting a new engine?
patty
  Skoda Fabia vRS
it should improve performance in my experience yes
you will most likely have to put the cat back on unless yours is a J plate....or, if you find a ;) friendly MOT bloke....
you can get it chipped mate....
  172 M69 eater
hmmm damn seein as mine is a n plate that means im buggered.... ah well only 4 screws...
thanks for ur help brun
patty
  Skoda Fabia vRS
np anytime mate
like i said though, try an get away with it first.........re-test is free.....you might find a dodgy tester
  172 M69 eater
i know a dodgy tester but if he gets busted id like to know i would b ok with a normal tester!!! ;) me thinks ill deffo do it
the only thing that concerns me are roadside emissions tests.... and if i get pulled over, if i fail ill get f*cked!
patty
