the end digit codes normally apply to slight differences in the engine design(pistons,valves,bearings,head,injection components etc).it might only be a very slight difference but it will be there somewhere. if you look at the k9k engine repair manual you will probably find some differences between the two numbers in that manual. some of the specs/meassurements etc will be different. you should have the k9k repair manual on dialogys.
