Djw Johns terrible cars and his bad decisions regarding them
Djw John
Scotland - South
Got to the point where it's just the slave cylinder and selector to remove then unbolt the box and mount and it's out. I expect it to be really light and easy to remove....
I know you don't have to remove the struts but it's getting lowered so may as well do that just now too.
Im not sure how many nurses hands look like this though...
Djw John
Scotland - South
£480 deep into this. And still don't have a box 😂
Renault pricing continues to be mental.
Clutch £143
Slave cylinder £152
Front shocks £81
Top mounts £72
So clutch is coming from RPD (on 2 week back order) and other bits from Autodoc. Granted the shocks and mounts aren't really an issue but I'm putting eibachs on so may as well refresh it. Seeing as how I'm financially stuck with it forever now 😂
Brigsy
  Kangoo 172cup
Can get the slave loads cheaper if you sniff round. I just found a meg 250 genuine slave for £30 new on ebay, same part number as traffic iirc
I share your pain with prices though. Im something stupid like £1300 deep in a clutch and bush change on my Kangoo, parts only. Everything seems to be expensive on the 2.0 turbo.
R3k1355
I'd like to take this moment to remind you that you let a perfectly good Leon go to embrace this utter pile.
Djw John
Scotland - South
I did do some other stuff before finding that, was just a pottering sort of day.
very shiny
Then spotted the difference and took them all apart for the f**king bump stops and s**t guards. Neighbours almost certainly heard me shout MOTHERFUCKER.
I also painted my wiper arms and scuttle. Fat lot of use that is, like putting lipstick on a pig. No pics cos I'd rather lost my mojo by then.
Djw John
Scotland - South
New one has arrived. More movement in it than I expected tbh but I've never seen any dmf before!
Djw John
Scotland - South
Finally some progress. It's been emotional. And tricky to fit into life.
Shiny new dmf
You can see the difference between standard and 250 spec stuff here
and fitted
@Djw Dave is a very useful friend to have, perfectly sized
and in
The old clutch fluid was original I reckon
now just to try and get a clutch pedal on the c**t.
And finally, had 9 cars here yesterday, I'm defo being talked about in the street 😂
Brigsy
  Kangoo 172cup
Clutch will go easy. Just hook up a large syringe to the bleed nipple on the slave and pull 30ml of fluid out and you will have a good enough pedal to drive straight away. They are piss easy not like mk2 meg which can be a c**t to do
I spoke to John yesterday and explained how much of a chuff it was to do on my 175, it seems to be the same setup🤣
Pressure and vacuum bled mine for 15 mins, nothing. Left it for 30 seconds, heard a big slurping noise and the pedal was mint🤣🤣
Djw John
Scotland - South
Hows the yellow Leon doing?
pretty well really, 136k now, had it over for a new washer pump whilst my bro was away so used it for the week. Probably shouldn't have sold it
Don’t think the icy will take that ginger bottle back now.
Challenge accepted
If that doesn't work then you're coming up to help me. Kthxbai
R3k1355
Does the clutch and/or DMF have a break in period? Might be worth checking before you give it some.
