Do you need a press for new rear discs?
  CursedTitanium 182FF
If you purchase them from either Renault Wolverhampton or G 172 on here, they will come with the bearing already pressed in.
George@RTR_Parts
ClioSport Trader
You can get rear discs with and without bearings fitted
But it's false economy imo to change the bearings on their own (for good quality bearings anyway, like what come fitted in Brembo or Renault rear discs)
But yes they'll need pressing in/out
Check if these spacers are present mate dann2707 if you are having bearings fail prematurely (which I presume you are if have life left in disc):
http://www.cliosport.net/forum/show...cer-that-go-behind-rear-discs-on-Clio-172-182
Or it just might be all those multi storey car park frolics taking its toll on car pal :p
dann2707
Thank you for the replies! Just had a look and apparently they do come with the bearings already pressed in along with the abs rings fitted so that's cool.
Thanks G 172 for that, btw your brakes came today, only just got around to fitting them, thank you very much for a speedy service :) Really pleased with that.
