DS2500 Dust Question
Coops Mk1
  Lots of Scrap...
Considering some new pads for the 182, however I am a bit of a tart with my wheels and I don't want to shag them with un-cleanable dust
are the DS2500 manageable in terms of dust? the RC6 I have on the mk1 have basically eaten my superleggera's and I don't want a repeat performance on the Williams wheel's I've just had painted, however I want a bit of bite on the brakes and the standard pads are not living up to my expectations coming from the mk 1
Coops Mk1
  Lots of Scrap...
its not so much the amount of dust as the consistency of it, basically the RC pads are just metal filings that come off the pad and weld themselves to the wheel, literally cannot get them off and the wheel turns rust coloured, nom nom. I wont be happy if something similar happens to the willy wheels on the daily
sbridgey
  disco 4, 182, Meglio
They can't take heat well at all. And the stopping power is mediocre IMO.
I ruined 2 sets of discs running these pads on track. Stepped up to DS3000's and the stopping power was considerably better and they didn't ruin my discs.
Coops Mk1
  Lots of Scrap...
and please keep a debate about how good they are to elsewhere, i'm more interested in the original question ;)
  E46 M3 & UR Quattro
Another vote from me, I think they are a great all round pad. Dust isn't the worst I have experienced, as above it doesn't really bake on the wheels like CL Pads so it shifts pretty easy.
  S4 Avant
If dust is what you're trying to avoid Ben, I had yellowstuff pads off adam for something daft like £90. They aren't as vicious as the DS3000s I put in after, but I could keep on top of the wheels being clean.
bozothenutter
I have Ds2500, ran them on my first trackday so they hardly got heavy use.
I left the dust on the wheels for about two weeks...no problem in wiping it off....the Ironx I used after did go mental though....
Coops Mk1
  Lots of Scrap...
cheers for the advice folks, I think I may give some a try
Dave, I've used EBC before in all 3 flavours in the turbo, dust is as you say more than manageable but I've never got on with the pads tbh
George@RTR_Parts
ClioSport Trader
Easy to clean off as an oem spec pad dust ime. Give your alloys a good clean and use a wheel sealant on them and a quick hose off will remove most of it
  Clio 182
I had them on my Leon with freshly painted wheels. I ran all winter without cleaning them and the new paint was fine and the dust washed off.
  Cup In bits
They aren't a metalic pad so can't rust your wheels paintwork. I do track days and leave it baked on for a month sometimes, some g101 and a mitt and its off.
I find them mediocre in my Meg 225 callipers and they warp my disks slightly on track, the disks do straighten a bit when you do a cool down lap, haven't used them in standard callipers though.
  182/RS2/ Turbo/Mk1
Warping disk is down to heat rather than pad compound surely, so therefore the only way to avoid that is better cooling or worse pads or brake gentler.
Ie its not really a fault with the pad you are using, but with your cooling or your disks
  Clio 172 phase 1
Stay always from black diamond ... Got a set thru work overall the performance is good when cold and good when hot but when just warm ( pottering round town ) there shite and the dust is unreal 2 weeks of short journeys and a few 40mile journeys and my wheels are brown with dust and its a caaaant to scrub off
  Cup In bits
Not this argument again, I have to brake first/longer compared to a mates Clio on RC6 so I think that's where the heat is coming from, I get a slight warp which then almost disappears after they are cold and normal driving resumes. Without appropriate cooling I think they will stay warped.
Sbridgey echo's this problem and from what i'v read he's the last to blink on the brakes and has tried various compounds so I stick to my original comment.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
I'm a bit late on this one but my 10 pence worth...
I didn't rate the DS2500 and I killed a set of Brembo discs and these pads on track earlier in the year. Not a particularly amazing stopper either IMO especially not for the money.
I run the DS3000 now but that's not what we're on about here.
Before going to my current setup I went with Brembo discs and Brembo OE compound pads and actually thought they were just as good as the DS2500 but more importantly less than half the price!
  Cup In bits
+1
I ran the OEM Megane Brembo pads (£30 pad) for two track days this year after fitting my callipers, I then went to DS2500 (£160 pads) and there wasn't a massive difference in performance, the brake fluid started to seep out the brake bottle with heat and I get a warp in the disks and melted 3x team dynamics centre caps.
To sum up... not really worth the outlay, there must be better non metallic pad (no paint damage) out there for the price.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
It's all down to driving style and personal interpretation so completely a "horses for courses" issue but I will never buy or recommend anyone buy DS2500's as an "Upgrade" when the OE Brembo compound does the same on both road and track for less. This is what I always buy from George/G-172 when customers ask for brake parts and they've never let us down or had complaints.
Mick
  Lotus Elise
I disagree. I don't think they are good at all.
Yeah but you're an animal lol.
The dust just washes off but they do generate a lot of dust but strictly speaking they are not a road pad which are designed to generate less dust.
  Lotus Elise
This entirely. A better compound will generate more heat, the only ways to reduce the heat is bigger discs, bigger pads or ducting or of course a worse pad.
Wow totally off topic in under 1 page.
The dust is quite a lot worse than normal road pads but it doesn't eat into the wheels at all.
I've run DS2500's on both standard calipers and 4 pots for 3 years now.
When you fit them give your alloys a really good wash inside and out and put some wheel sealer on them. You'll find you can just wipe the dust off when washing it with a rag, it's dead easy.
As for the heat issues - the problem with DS3000's on a road car is they need to get hot, not ideal unless it's a fully committed track car.
The DS2500's do overheat on standard calipers but I find that's just because the standard brake setup is s**t for dissipating heat even with brake ducts.
The DS2500's in my 4 pots at cadwell VERY heavy on the brakes everywhere and they never overheated or lost bite once.
  Lotus Elise
​4 pots are king
  DON'T SEND ME PM'S!!
I'd honestly just stick with good quality standard spec stuff. ds2500 are over rated and over priced, I agree fully with sbrigey, they're not very good at all
