Dual Optic Conversion HID help... SE area HELP!
So i've done the dual optic conversion a while back...
now the passenger side HID decided to stop working, swapped bulbs around, wasn't the bulb thats work, checked wiring, all seemed fine, got a new replacement ballast... still no luck!
anyone in the south east/west kent/kent area willing to help?!
would say beer tokens are involved but im only 17... so yanooo ;)
What amp fuse was it??
Sometimes hids blow the 10/15 amp fuses wheras a normal bulb wouldn't.
Just pop in a 20 and it should be fine.
(don't go any higher then a 20 though!)
Otherwise something else is wrong.
If it does blow again try a normal bulb and see will it work!
the driver side has a 10 amp in and works fine...
put a 20 in, didnt blow, but didnt light it up either, im thinking a short somewhere :/
