a while back i changed my fuel filter and in an effort to de-compress the fuel system i tried removing the fuel pump fuse from the fuse box under the scuttle panel (engine bay) and found the folloing
Without the fuse the car wouldnt even turn over
If the fuse is removed once the car is running it didnt seem to have any effect depsite running it for a few minutes to release the pressure?
The fues itself was a twin blade standrad fuse, but unlike normal its was avery loose fit and was only really held in by gravity itseems. This worried me that the power to the fuel pump could be cutting out and possibly making the engine lean off a bit with possible catastophic effects of course.
are they all like this? am i worring about nothing?
