engine conversion help please!!!!
  Clio 16v
Hi all i have managed to pick myself up a willi engine/gearbox/ecu/loom etc to go in my 16v. was wondering if anyone knows if its a straight swap or do you have to change the driveshafts and any other bits???? Cheers
  BMW 535d
You only need Williams shafts if you are changing the suspension to Williams suspension
You need Williams manifold, downpipe and de-cat/cat
Williams ecu and the wiring loom off your old engine. Dont use the wiring loom on the new engine.
Everything else really is the same
Conveniently i have all of the above. downpipe, cat and manifold. Yours for 120 posted :D
Might be worth asking over on C16valver.
What gearbox is in your 16v? I believe the Williams has a wider track so might need the shafts? Just guessing though so wait for someone who knows to answer.
  Clio 16v
I have a k-tec stainless manifold and down pipe on there at the mo, why can't I just use this? Surely the fitting is the same!!?? Cheers
  BMW 535d
Ok if you have a ktec one then use that.
You didnt specify that did you
You are good to go
