ex Clio 172 owner :(
Hi dudes, little bit off topic as Ive got a VTS but I cant be bothered to get mucky and stuff (and its cold). Ive booked my car for an oil change next Monday after work, but the car will be hot. Is that ok? The mechanic says it is as the oil will be thinner and drain easier. Id have thought it was better for it to all be in the sump and very little left in rest of engine.
For best results, what would you suggest?
If I do get it done on a hot engine, will it be ok still though?
Any recommendations on which oil for a VTS? (I asked Saxo lot on ssc without much help)
Cheers budsters.
