mgoode180566
172 Sunflower
Having just fitted a new engine to the phase 1 it started first time with no engine warnings.
After a few test starts i found it wouldnt idle below 3000rpm and the engine warning light came on. On closer inspection i found what i believe to be the hose to the braking system had popped off the manifold causing an air leak. Pushing it back on restored the idle to its usual level but the engine warning light has stayed on.
Will it eventually go off by itself ? How can it be reset ? Im sure there is nothing a miss. Car runs fine with what seems to be full performance.
