Monaco
First of all I'm aware this is fairly useless without pictures but it is way too dark to take any. I got home from work at 9.30 and was a bit bored so fitted it straight away . So I kind of need help from people who has fitted one (or a JMS set-up/ Ph1 172 etc.)
So my first observation was that there is one less intake hole. I knew this before buying it and am aware that the larger 100mm diameter V6 hole delivers potentially a lot more air. However i had to disconnect the smaller of the two standard intake pipes. Now I'm a bit of a perfectionist and I'm not too happy with just having the hole there so wondering what other member's solutions were?
Another thing; I fitted it to the existing engine-to-airbox Pipe/hose. This is because it had a sensor in it and was scared to tamper with it. What is this sensor? I also did not want to trim this hose down due to the fact I'm not 100% sure I want this induction set-up. This means it is a very tight fit. So tight that it is actually fouling on the fan housing. is there some way of holding it in place? A bracket maybe? Again... what were other members solutions to this?
Finally - now i haven't driven it yet - but i fancy getting a performance filter. I was browsing the BMC range but couldn't actually find the right filter (they usefully have the dimensions of each filter on their website but none matched mine). Where and what have members managed to get performance filter wise for the Espace V6 box
Any replies greatly appreciated.
/boring_read /School_boy /tired_now
[EDIT] I should add i will get pictures of this tomorrow morning for about 9ish to aid my description
