fitting lowering springs
Matt e
hello
im currently trying to fit my sportlines, but im having some bother. i cant foir the life of me get the damper and hub bolt holes to line up
does any body have any ideas what im doing wrong, ive got both wheel's off the floor
matt
anyone local to Stevenage area able to help?
You need someone to help ideally easy then. Dont be too rough with the hub assembly dont want to loosen the driveshaft and spill the oil out your box
  FF Clio 182
Make sure both front wheels are off the floor otherwise you will be fighting the ARB.
Put strut in and lightly put on the top mount. Try and line up the bottom holes and get a bolt through then all you have to do is pivot the hub up and give the other bolt a tap with a hammer to get it in :)
