Golf PD130 Banger
DaveDreads
Might have been Kim and Wayne, tbh everyone got a windscreen of dog hair when they followed me, that dog shed more than any animal i've ever know.
Flat Eric
  F31 35d, Berlingo Na
Yep makes you wonder where the years go how long ago was that bout 10 years?
Would've been 9 years.
I had my 182 when I turned 21 in the January, so would've been 9 years January just gone.
Still a long time ago.
DaveDreads
Used the arm rest for the first time today and it lasted about 10 seconds before it got folded back up after discovering it makes it difficult to change gear, I don't remember my last MK4 being like that, proper pissed me off as I was looking forward to full armchair spec cruising.
Stefan.
Still can on the motorway though?
I found the same with my audi s4 the armrest was in the way/felt weird when changing gear.
DaveDreads
I was using it on the motorways today, set cruise control, sit back and chill.
I did find a way of changing gear with it down but it's a bit awkward, so iit'll stay as a little bonus of being on the motorway.
R3k1355
Have you checked/replaced the shifter mechanism? Did the cables and bushes on my Leon, made a big difference to the shift.
DaveDreads
That was all new when I bought the car, the changes are solid, in fact i've had to change my shifting technique as the Clio taught me to be gentle and nurse the gears into place, the changes are so solid on the Golf that if you do it gently you sometimes miss gears from not being forceful enough, so now i'm just slamming them in and haven't missed a gear since.
DaveDreads
Went to change a bulb and found this, there isn't one on the other side and it's zip tied so it can't be plugged in, any ideas?
Also the coolant system is leaking from a few places now after hammering it up and down the motorway to London on a regular basis, so i'm just going to replace all the hoses, clips and connectors, possible the radiator depending what state it's in.
What I don't understand is why the PD130 hose kit is more expensive than the PD150 kit, the photos look identical but that could just be a stock photo, it normally tells you if the photo isn't the exact product you'll receive, the PD150 does have a different intercooler setup so maybe some hoses need to take a different route, i'll be running a front mount eventually so the standard setup will go in the bin anyway.
I've no idea what to buy now and these are the cheapest kits I can find, as far as I can tell the products are identical.
Pd130 £210, but it does come with clamps
PD150 £176, £40 cheaper but no clamps, I doubt clamps will be £40.
I'll probably go with Darkside but I thought i'd ask for opinions.
Coops Mk1
  Lots of Scrap...
Hasn't this thing given you consumption or gonorrhoea yet and caused you to chuck the towel in?
DaveDreads
The interior was quite clean until I put the dog in it, the car is surprisingly rust free and tbh i'm not really the one that's doing all the work, i've helped on every job but once Guy Martin gets the bit between his teeth sh*t gets done.
Nah you wanna be in the groups on Facebook, most people are properly retarded but there are plenty of helpful people on there
Most of the Golf pages aren't that bad if you can prove you can spell and have 3+ teeth
I'm already on a few, but I only use FB for cheap parts.
