Grease to use on injectors?
  Ph1 T
Finding it abit of a fight/struggle to get my injectors I'm on the engine end not rail is there any sort of grease that can be applied to make it slightly easier as Dont want to damage anything (again)
  182cup & 172 racecar
Got any white grease spray? If so, just spray a little bit on your finger and wipe it round the o ring.
  Ph1 T
Haven't tony only thing I've got left is WD.. Will try spit got them in erlier but ones pissing fuel out.
  DON'T SEND ME PM'S!!
the one at the engine end won't leak fuel out, that will only cause an air/vacuum leak if it's not sealed.
  Ph1 T
So the only place it will piss out is the fuel rail end? Even if not correctly seated in the engine end?
GrahamS
  335d
I always use rubber grease like you would on brakes, makes a good seal and pretty sticky, been doing this for a couple of years and never had trouble
