Hazard Lights - 172
  Clio 2.0 172 Sport
Can anyone shed somelight on why my Hazard lights wont work. I have checked the fuse which looks fine and the indicators work fine but when I press the Hazard button I get nothing? Could it be all bulbs have gone?
  Clio 182 FF
Hi,
I have exactly the same problem in my 182. I have replaced the switch and still nothing. I get it lit up when the lights are on but there is no one home. Can anyone tell me what else might be the problem? Could it be the relay or a fuse?
  Clio Sport 172.
I have just bought a phase 2 172 and I have exactly the same issue! Its a common fault, I have a friend who works for Renault. so when he gets round to fixing it for me I will post the solution on here.
  Clio Sport 172.
I just replaced the switch itself, simple fix. Just pop the rectangle unit out and disconnect the old one. Slide in new switch and connect. Job done. About £8 from eBay.
  Clio 182 FF
Could also be the switch..
I have replaced the switch but still nothing. Could it be the fuse for the UCH or the hazards themselves? Could it be wiring as the bloke i bought the car from had replace the stereo. Worst case scenario... How much is a new UCH? Can the one i have be repaired?
