HELP!!! 182 wont rev and a heavy smell of eggs
J
jonnytheboy
Problem started last night, started car and it ran lumpy and wouldnt rev over 2k then it was fine. Started car up this morning and Emissions warning light was on and the same thing again, got about 100 yards down the road then a heavy burning eggy smell. Any ideas?? Smells like its CAT related,. PLEASE HELP
  182 Turbo Project
Sounds like the CAT is fooked to me mate, if it's an eggy smell with emissions light on?
J
jonnytheboy
Thats what i thought, I,ve heard the coil pack can cause a similar problem due to only firing on a few cylinders
J
jonnytheboy
Cheers mike, i'll check if anything is loose when i get home. Will it come up with a code if thats the problem??
  Clio 1.4 1999
When mine smelt eggy it was misfiring, because the coil packs had gone, but if the emission light is on it could be the lamba or cat.
  Focus RS + S3
sorry to hijack, but i occasionally get the eggy smell too with no lights on dash, is it the same prob as plugs coilpack etc?
thanks
J
jonnytheboy
Well if it is the coil pack/plus/leads then the emission light would come on as tha car is not running well ie, lean/rich
  172 Ph1/Scooby MY00
Interesting read. Mine stinks a bit, too. Occasionally misfires as well. Any idea of the cost for new leads and coil pack (you'll also need a gasket for the plenum and a seal for oil breather)?
J
jonnytheboy
Had a look to see if anything was loose and checked plugs and HT leads all ok i think, each time i start the car it runs fine for a while then starts to run lumpy and the emissions light comes on, code is PO135. So are we talking coil pack or lambda sensor
J
jonnytheboy
All sorted now, waited till it got dark and saw a nice arc on one of the leads, so gonna tape it up for now and order some new ones. :D
