Help Me!! Wireing HeadUnit
Hi, ive just got a new MP3 head unit, and its an ISO connection..here-
http://http://www.caraudiodirect.co.uk/product_info.php?products_id=3199&tab=4http://http://www.caraudiodirect.co.uk/product_info.php?products_id=3199&tab=4
BUT! My car has been "tampered" with, by the previous owner, What do i need to fix this?? It looks like this -
http://img.photobucket.com/albums/v312/owensmorgan/Picture13.jpg
[Edited by DEAGLE on 20 January 2005 at 12:07am]
[Edited by DEAGLE on 20 January 2005 at 12:08am]
[Edited by DEAGLE on 20 January 2005 at 12:09am]
  Polo + Micra
i think youll need a female iso block with bare wires comming out of it and a multimeter
As dink says a female ISO and a multimetre, I could guess a few of them but its always best to check with a metre.
ISO Repair connector for Car Harness
ISO Male to Bare ends
http://www.nexxia.co.uk/head_unit_fitting_kits/images/PC3-08.jpg
PC3-08
This adaptor can be used to repair or convert the wiring loom of your car for the modern ISO type connection used by all Aftermarket radios.
£4.99
http://store.securehosting.com/stores/sh200552/itemdetl.php?itemprcd=PC3-08IMG height=16 src= http://www.nexxia.co.uk/images/addtocart>
All prices include VAT and Postage
[Edited by Pete on 20 January 2005 at 12:32am]
Thanks man, i was going to get that one, but when i heard "female iso block" it threw me a bit, Thanks again!!:)
  Skoda Fabia vRS
you can get one of those at any Motor World branch mate, think ive got at least 2 of em in @ the one i work at
  Skoda Fabia vRS
they aint the same colour mate so it wont be that easy
(dont cut the H/U harness, these cost about £25+ to replace)
  Skoda Fabia vRS
there is a pic of what wire is what on the clio wiring on this forum somewhere
try and search for that
or, find someone else with a Clio and have a look at it
Pink/Purple/Beige/White Speaker Wires
Black Earth/Yellow Ignition/Red Battery via Fusebox/Blue Dash Illuminaton
Check with Multi to confirm,Megaohm speaker wires to find left front etc
  1.8 RSi MK1 Superchipped
Im having the same problem but for the Mk1... anyone help witht eh wireing on this one? Im getting the block at the weekend...
Hi, im still having trouble with this! I went to a Car Dismantler yard near me, and cut out the wires with a block on from a Clio a year later than mine. When i came home, i wired it up colour to colour. And hooked it up to a head unit. And it wont turn on, nothing happens! Ive tryed changing the fuse. What can i do? How do i tell if the fuse has been blown?
THANKS For any help
SORTED! managed to do it, but i still have 1 problem.. when i turn of the egnition, and restart, the memory of the head unit has reset.. Anyone know how to get around this?? Thanks
  Polo + Micra
sorry m8 forgot to reply
there is some time bullet connectors on the wiring harness for the hu.
plug the red to the yellow and vice versa and that should sort it
Use multimeter to check power supplies.
With ignition off.RED 12V/Yellow 0V/Blue 0V.Check fuse in dash if no voltage
With ignition on.RED 12V/Yellow 12V/Blue 0V.
With lights on. RED 12V/Yellow 12V/Blue 12V.
If all is OK,Check Black to Ground for 12V.Should be 0V.If not there is a short.Put multi to ohms and check again,should be 0ohms.If this is OK check the two inline fuses on stereo again with mega.On some stereos there is an internal fuse this could have blown also?
If you have no meter use a 12V bulb/holder and a couple of wires.Better with the multi.
This should help?
