Hi-Spec 4 pot kit for 1*2
  340i
Does the 4 pot, 300mm disc kit fit behind a 15" alloy (O.Z F1)???
Also... peoples opinions on these kits, braking power, wear rate etc..
Jamie
Alright Gray, I have had some Hispecs and was not bowled over by them tbh. If you get them for cheap all well and good but I would consider other options.
  Clio 182
Hispecs are appalling don't bother wasting your money. The quality is terrible by comparison to OEM calipers. If you really want 4 pots make your own from a good OE setup i.e clio 197, fiat coupe turbo etc.
You will always have problems fitting them under the usual clio wheels because of the offset and spoke clearance. Better sticking with the standard caliper and upgrading the other parts. How fast are you planning on going? :D
Laters, Donut.
  340i
I already run Brembo Max discs, PF97 pads, s/s brake lines etc..
Was just curious more than anything :)
  Clio 172 cup
I had a hispec setup on my Williams. Complete waste of time and money IMO
A Clio just isn't heavy enough to justify moving to 4 pots
