As title suggests i've developed a very concerning whine at high rpm from the engine, loudest on heavy throttle and particulary when rolling back down the gear from above 6000rpm. At low speeds and cruising theres no noise.
Aux belt is new, tension is fine, all pulleys are smooth and quiet to spin with no play in them too. Possibly an air leak from somewhere, but sounds more like a sucking noise so vacuum leak?
Car is a 2000 Ph1 with removed aircon.
