How 2 get a 172 on ramps
Well it is standard, and all that happened was i took a chunk out of the front bumper :(
Looks like im going 2 have 2 use a trolley jack and axel stands
Lee
  BMW M2C
I used axel stands when I put the front splitter on as I found it wouldnt have cleared the ramps.
Lee
  BMW M2C
Quote: Originally posted by wackojacko on 14 May 2004
No. Im clearly to gay to take the zorst of my car. Time to be nice to people in a gargage.
lol, I put mine on the ramps to move my exhaust a while ago and soon gave up. Ill be doing the same as you in a few weeks when I remove it. Sod getting under the car. :D
Where is the best place to put a trolley jack under it ?? (brake pads this time)
All i can see is sill and soft looking stuff. No jacking point. And i really dont wanna use the sill crusher !!
  Mk2 V6, MK1 Track Sl#g
my 1.2 wont go on a 2 post lift with out a trolly jack, come to thing of it it cant get on a 4 post lift either going forwards
there should be 2 strengthening bars under the car just behind the sills to jack up on approx 4 inches away from sill!!
Lee
  BMW M2C
I risked using the jacking points!! I was very careful then placed an axle stand under the cross section of the wishbone.
You may want to place a large bit of wood in between the jack and the jacking point to spead the load a little, Im sure youve read how they like to bend.
KDF
  Audi TT Stronic
You can get a 172 up the ramps, just put a block of wood under the ramps to lower the angle.
wackojacko,
Try these pages from http://www.rs-team.orghttp://www.rs-team.org
Front: http://www.rs-team.org/Html/Prepa/Liaison/plaquettes_av.htmlhttp://www.rs-team.org/Html/Prepa/Liaison/plaquettes_av.html
Rear: http://www.rs-team.org/Html/Prepa/Liaison/plaquettes_ar.htmlhttp://www.rs-team.org/Html/Prepa/Liaison/plaquettes_ar.html
Very good pages with lots of pictures, unfortunately they are in french, so you will need to run these pages through a language translator such as the one on google.
Chris.
it takes about 5 mins to change the pads :)
take wheel off theare 2 bolts on th back of the caliper 13mm and 17mm i think remove the bottom and loosen the top swing caliper up pull out pad grease the new one up slide it in then reverse the steps
