mx5
If i pull away under 2k revs, the whole car judders and it sounds horrible. I read on here that is you can move the engine with your hand it means that the engine mounts are gone. But how much movement are we talking, like mine moved back and forward a good centimetre, is that enough to be worried?
Not very mechanically minded, so how much should i be looking at to get it sorted by a mechanic? and which mounts would need changing?
thanks in advance
thanks in advance
